Odd noise when pulling away
Hi,
I wonder if anyone can help.
I have a 2000 Reg Fiesta Finesse. Pretty basic but has power steering. Recently, when pulling away, there has been an odd noise that sounds like a flat tyre going round and round as you speed up (its not a flat tyre) As you get faster the noise speeds up with the car and when you reach about 20mph it fades away.
Does anyone have any ideas as to what it could be?
Ive looked under the front of the car and in both front wheel arches and cannot see anything loose.
Any help would be greatly appreciated,
Jon
Hi,
Jon
Could be start of wheel bearing failure? Does it come back with hard cornering?
Normal places to look are suspension parts, bushes and wheel bearings. Also could be something stuck in your caliper although usually that gives a squeel.
check if it does it in all gears or just first i had a similar problem on my escort gti and it turned out to be the gear oil was low
