How Can I Prevent A Major Turbo Failure (Focus 1.6 Tdci 05)
Dunno really... when I was thinking about doing the job I did wonder if I could get away with taking the sump off with the pipe in place, but as I always intended to tackle the turbo oil feed I didn't investigate. Its not accessing the bolts that's the issue, just the fact its just generally in the way. You could get under and have a look, measure the length of the 2 studs vs the gap between sump and exhaust, add a bit for manouvering and add a bit more for luck, and if the gap's bigger than the stud then I guess you might get away with it. You can access all the bolts with the exhaust in place I think, though tightening you should use a torque wrench...
Haynes manual Sump Removal section says remove cat section of exhaust in step #3. Ford's ETIS software doesn't mention it though.
Before I ordered any parts I made sure I would be able to get the exhaust off by undoing a couple of nuts etc, so if I were you have a look under and see what you think.
  • Replies 51
  • Views 76.9k
  • In case anyone's interested, did my car over the weekend, replaced banjo bolts, feed pipe, sump off, cleaned out etc. Car is a 2008 90bhp with no DPF, on 58000 miles. Serviced twice by Ford at 14k and
  • Regular... oil... change... I cant imagine what they have been smoking when they decided that the intervall for oilchange should be 12k miles... Mine was serviced by the book, every 12k on ford, and a
  • Regarding this topic I've had quite a lot to do with the 1.6TDCI engine. I work for Citroen as a tech and we have had loads of total engine failures with this model on the C4 Picasso. We regularly h
Thanks Graham. I think if I'm going to the trouble of taking the sump off, I might as well check the banjo filter as well. Probably better to do that first as a base line and then just do the sump clean procedure every year after to be sure?
Just ordered the Haynes manual as it will always come in handy I fear!
