sunroof open/closing
With Global Open/Close Door/Sunroof, This is from my Ford Etis online build , just wondering if this means when i Global open / close my windows does the sunroof open /close at the same time ? I have tried it but sunroof has to be closed manually, anyone else tried this on there Edge.
Asked the same question and the sunroof does not close or open with global closing or opening.
Which defeats the object really!
I suspect because the sunroof has no limit protection (i.e. in case of something being trapped in there), plus it probably takes way too much power (shade plus glass) when only operating off the battery.
You could also query why the windows don't auto global close when you lock (on full guard) the car too!! No point having the alarm on, if the windows are still wide open ;-)
I can't seem to get my car to do a global open - should this be a feature on my edge?
I'm presuming your just pressing and holding the unlock button on your key fob?
It also need that you set the up/down limits for all windows before it works ...
1. Lift and hold the switch until the window is fully closed, then release
the switch.
2. Lift the switch again for one more second.
3. Press and hold the switch until the window is fully open, then release
the switch.
4. Lift and hold the switch until the window is fully closed.
5. Open the window and try to close it automatically.
6. Reset and repeat procedure if the window does not close
automatically.
Do for each window.
Thanks Simon - that's done the trick- much appreciated
Dave, you'll find that after a service you have to reset again as disconnecting the battery loses the settings!
You may have noticed also that the one-shot open/close from the internal switches doesn't work until the windows have been setup either.
Thanks again
