DPF sensors
Hi so Im suffering with the dreaded DPF problems.
It will never regenerate itself nor forced (driving at high revs etc).
Had it removed and fully cleaned out also, and the ECU updated.
lambda sensor replaced and one of the DPF heat sensors as it was reading at 900 degrees.
So I have just got that FORscan program to look at how it is since leaving the garage its gone back into limp mode etc a few month later ( I do about 600 motorway miles a month) now the sensor that I bought from ford direct is still reading at 900 degrees and the other 100 degrees, so im assuming this is the issue, also FORscan does static regens on some cars but of course not mine so is there any programs out there etc that can ?? better than paying god knows how much its cost me upto now in regens cleanout sensors etc.
Many thanks
Mike
