Failed Nct (mot) on high idle emissions
 had my nct last week and failed on high emissions.
Ford focus 1.4 petrol 2005
Low idle co 0.09 vol% pass
Lambda 0.98 pass
High idle co 0.66 vol % FAIL
I PUT DIPTANE and drove it hard. Put another bottle and did italian tune up on motorway before test. Reached at test centre and car went for nct straightaway.
Now high idle co is 0.42% . Still fail
Changed the cat 2nd had. Put new coolant temp sensor and went for retest but no luck. New readings are
Low idle co 0.09
(810)rpm HC 26 ppm
Lambda 0.98
High idle co 0.66
(3150)rpm HC 96ppm
Engine oil temp 83 c.
Then went to garage for diagnostic and he found no leaks or no problems on obd. Only thing is post cat sensor readings are not static. Advised for new cat. But the guy who sells the cat suggested that nee cst won't make any difference and find out the original issue.
Car is burning oil and now I have no idea what to do.
