Focus mk2.5 pollen cabin air filter replacement
Hi
I have an automatic mk2.5 with a left-side steering wheel. This video about a left-side steering wheel manual mk2 (I do not know if it is different compared to an automatic mk2.5) shows that I need to remove the gas pedal. The video at 2:05 shows the removal of the gas pedal after the removal of 2 nuts that fasten the gas pedal. I removed the two nuts (shown below), and the pedal still can not be removed. Any help will be appreciated. Thanks a lot
There's a third nut to the right of the top one. Pretty fiddly to get to and easily missed.
Thanks. I found it. Do you know the tool used to unscrew it, given its hard to reach position?
Not sure. A universal joint and an extension should get it.
