Reversing Camera & Forscan
Hi I have retro fitted a reversing camera to my Ford Kuga 65 Plate (UK). I did have details on how to enable this is the Sync2 system using for scan. From memory it was changing a few digits. Please can anyone help me and point me in the right direction to "Enable the Camera" using Forscan.
Thank you Simon
  • 1 month later...
Thank you Simon
Hi simon I have been searching for weeks to find out if any body has codes . I have put my car into our local dealers to see if they can activate it with no joy . I have now come across you & wondered if you had any joy with forscan & programming
  • 1 year later...
Taken from the ForScan forums:
Try the folowing,
1- Go to the APIM As-Built
2- Do a backup of your original APIM (just in case)
3- Change block 7D0-01-01 x*xx-xxxx-xxxx
*=3 With camera no PDC
*=9 No camera with PDC
*=B With camera and PDC
So you would change the * to either 3 or B depending if you have PDC.
Try the folowing,
I installed a boot latch camera on a 2015 Ford focus followed these procedures and all I'm getting is a black screen any idea what's wrong?
better off checking on the ForScan forums mate - I just pulled them from there and shared here.
  • 2 months later...
I used these instructions on mine yesterday and it is working great.
Try the folowing,
  • 7 months later...
Hi ,
I want to fit reversing camera to my ford kuga 2019, I can get wiring harness for £40 to fit straight to unit. However they all state "Needs code added", doe anybody know were to buy coder that plugs into pins to do this . thanks  tom
