Heated seat
A few times recently the drivers heated seat has been on full when I start the car. Passenger side doesn't come on, and its not been all that cold. Any ideas anyone? 2018 Titanium.
What was the outside temperature? Was your heated screen automatically on as well?
My heated seat have never come on by themselves. Even in very cold weather last year.
it should only be controlled by the heated seat switch I'm sure or maybe through the touchscreen climate control which I never use really
Mine have never some in on their own.
Probably 14 or 15C . Not cold. Heated screen not on.
I know if you leave mine on when you switch the car off, when you restart the car they come on again, try turning them off and try starting the car again?
I've sometimes found the rear seat heaters on when the wife has opened the rear doors to put the shopping in !! No one had been in there or reached in there since the ignition was turned on. Not seen it for a while, but then again I don't check very often.
confused!
On my wife's EcoSport if you leave them on, when you next put the engine on they come back on, same with steering wheel, screens etc too.  That said my Edge has never done it.  Maybe it is a thing you can turn on somewhere?
It hasn't happened since. Odd.
  • 3 weeks later...
  • Hi the heated seats is under warranty it is possible pipes in the seat or kinked
