FORD KA MK2 AIR FLOW INTAKE PIPE
The retaining clip on air flow intake pipe has completely broken off (rubber moulding) and the pipe is therefore rattling at low revs.
Here's a replacement (https://www.ebay.co.uk/itm/FORD-KA-MK2-AIR-FLOW-INTAKE-PIPE-51806858/232986127494?epid=502524130&hash=item363f0e2c86:g:Vt0AAOSwGYhb2FaG:rk:1:pf:1)
A bit pricey for a second hand part and there's no guarantee I won't run into the same problem again.
Are there any alternative mods (enhanced performance) that I could try as an alternative?
  • 1 year later...
I am having the same problem! I wonder if there is a cheap fix!
Fiat 500 version is cheaper and new. They are the same car in the engine and chassis, just different designs.. so check it out!
https://www.ebay.co.uk/p/1825358925?iid=231244709583
  • 5 months later...
Cheap fix. Fixed mine with a nut and bolt. CURED.
