Rear Hub to trailing arm bolt torque
Hi everyone,
My apologies for my first post being a begging post!
I am trying to confirm the torque spec on the 4 bolts that hold the rear hub/bearing assembly to the trailing arm on an '09 Focus.
I am pretty sure it is 110Nm but this seems a lot for an M10 bolt.
If anyone can definitely confirm this I will make a step by step picture guide of the job as a thankyou!
Thanks in advance folks!
Do you mean the 4 bolts that fix the hub assembly to the knuckle?If so I would imagine it’s similar to my MK1 and a torque of 66 Nm 👍
The wheel hubs need to be tightened using the following procedure:
Step 1: Torque: 65 Nm
Step 2:
Stage 1: Loosen: 90°
Stage 2: 65 Nm
Step 3:
Stage 2: 65 Nm
Step 4:
Stage 2: 65 Nm
Step 5:
Stage 2: 65 Nm
This procedure is needed to avoid introducing stress/deformation of the wheel hub housing during assembly. This will reduce the risk of premature failure of the wheel hub drastically.
Thankyou both for your replies!
Writeup will hopefully follow tonight!!
Well, that all looks a bit fancy.
Last time (and only time) I did that rear wheel bearing job, I just tightened them up as tight as I could and that was it.
Perhaps I am in for early failure, but I doubt it.
ScaniaPBman.
ScaniaPBman.
The real world version is, just tighten them up lol
Animal !!!!😂
11 minutes ago, iantt said:
Animal !!!!😂
Hang on, do you hear that Ian?
DUGGA DUGGA DUGGA
DUGGA DUGGA DUGGA
What a surprise. , But I was dugga dugga dugga this afternoon on my son's car trying to get siezed bolts out rear shocks. Thought I was going to snap the bolts . Lol  bit of penetrating oil and out they came.
Obviously torqued them back up after changing springs.🤔
That would have been a Saturday disaster lol.
Especially on my driveway! And I'm too old to be messing about on the floor!
You could've let your son do it himself...just take a supervisory role instead! :biggrin:
Well, thanks for the input guys, job done today.
As promised, there is now a how to.
Cast an eye over if you wish and any suggestions Ill add them in.
Cheers!
