Upgrade Touch SCRREN Sync 2 to Sat Nav
Hello fellow Ford owners
Help required.
I’ve seen lots of posts with regards to ford cars being bought with Sync 2 touch screen Cd/Radios without Sat Nav, although they have the active compass for emergency assist. The screen shows Information in the top right corner + the Compass. I have the same in my Ford Kuga 2015. I’ve seen/read that if you change the screen unit to a Sat Nav screen/unit and install a SD card (maps) that will give you the Sat Nav on your touch screen. Is this correct.....help
No hardware changes are needed, it's all software based.
You need a modified elm327 cable (switchable in order to access programming levels that are usually only available to dealerships, laptop and the correct software (Forscan and Foccus) plus the licence activation hack and a nav data SD card (ebay).
Bannko is the wiz for this and has a long thread concerning the requirements / procedure.
Sent from my SM-G965F (S9+)
