Cill plastic edging/protection strip - Mk2 Titanium 2011.
I have 2011, 2L Titanium. Spotless car apart from a gap that has appeared on the plastic edging on the cill. Looks like its came unstuck as it's not damaged. Anyone used a sealant/adhesive to stick it back ?
adhesive should be fine to put it back 🙂
Tec7
Just don't close the door until it's dry 😂
I guessed adhesive would be fine .........but which ? For clarity the cill protective moulding is the one at the bottom of the cill which follows through to the lower part of the front wheel arch. Thanks for responses so far .........................
  • 1 month later...
Tiger Seal did the trick !  Tried 2 x types super glue initially without success. When using Tiger Seal be sure to use masking tape to give an unnoticeable repair.
