Ford Focus 2007 Radio Upgrade
Wanting to replace the centre audio console in my car but wanting to know what size it is so I know what screen I can put in to replace it?? Can someone help?
Is the current head unit rectangular shaped or an oval that's wider at the top?  Assuming it's retangular (with you saying 2007) you can't just fit a standard size "double din" unit because Ford use weird non standard sizes, you'd be looking at needing something like this which would allow you to fit a standard double din sized unit.
If you need a radio that's the same size as the one currently installed, Xtrons do ones that fit both the rectangular and oval shapes. Not a particularly cheap option, but would save having to get a new fascia/converter kit.  They run 7 inch screens IIRC, though not sure if you could do 7 inch on a standard double din.
