No remote locking or central locking from internal locks. But boot locks with key and alarm arms.
As titled, getting nothing central locking  wise but boot locks from fob and alarm activates/deactivates. Indictators flash on unlock too.
Any ideas? A donor fuse box fix this? I've read the locking unit is built in.
Many Thanks all.
Nobody at all encountered this problem? 😲🙈
Still stuck if anyone can shed any light please
are there a fuses that you can check 🙁
Cheers dezwez. I did look but it wasn't at 77. Which I found blows on fuse box 2.i switched back to original box and it's the same.
OK, update. I've swapped the fuse box as many pointed out the CL is related internally to it no change. But! The locking will work if I change the 77 15amp fuse. But blows straight away. Input this down to a failing lock motor maybe and disconnected each door one by one.... But every time it still blows the fuse. Both by key locking and internal lever locking. It locks. But the fuse blows in the process.
Any ideas?
  • 4 weeks later...
Maybe a short in the door to A frame harness.
