Electric Window Switch (front Passenger)
The passenger door window switch does work on my 'new' 2006 Focus Zetec Climate 1600 but the plastic trim it pushes into is hanging loose from the door.
It looks like the loose part has broken off from the part that attaches to the door frame.
There's a couple of used ones on ebay around £20.
Do I need to remove the door facia to fit a replacement?
Thanks for any advice.
I think you just prize it out from one end ☺️
Thanks for that info Dezwez
Slightly embarrassing, the plastic part had just come unclipped from the inner part that I assume is attached to the inner door handle.
Anyway it has clipped back in position now, it just needed a bit of extra welly to reach the clips!
glad your sorted it ☺️
