Radio
Hi all would fitting a lead acid battery and not the correct silver /calcium one effect radio over time and end up damaging inside as my dads focus 2010 radio/nav unit wont turn on as its damaged inside .
should not damage the radio but you need to use the right battery ☺️
Your radio needs a 12v supply, it could care less how it gets it!
It won't bother the radio but the battery won't last anywhere like as long as it should do due to the SmartCharge system shoving 16+ volts through it.
out of interest why has it not got the right battery on 🙂
Hello we have a moblie mechanic who we use regular and the old original battery finally packed in and he fitted a motrio one , he must have thought it was suitable for a ford and so did we , its lb2 number   but no mention of silver or calcium on it  , may be most assume any battery can fit a ford.!
