Streetka will not start
Hi
I was travelling home everything running sweet I turned on the drive and the car started to run rough, to the point it appeared to run out of fuel.
I have looked at the fuses and all appear fine which are located in the car right-hand side of the steering wheel.
Can someone point me to the correct relay for the  fuel pump, I`m not hearing any priming noise from the fuel pump,there are lots of relays at the rear of the fuse card but not sure which one is the correct one please can someone help.
Thereafter I can only assume it will be the fuel pump.
Thanks in advance
Jim
