Ford focus ecoboost 2013 no spark
Hi all
Bought a non starter a ford focus ecoboost 1.0 litre 2013 . Lots of fuel and.battery but no spark at all. No faults showing on my diagnostickets toold after resetting . Had ecu and body control unit checked. Any ideas and also checked the immoblizer system everything fine
Are you using Ford diagnostics or something generic?  Would be worth trying Forscan if only using generic.
Would check that cam and crank are synchronized as a start as they won't fire if not.
It's a snap on diagnosis tool . Will it do any damage if they are slightly out..engine got full compression
  • 1 year later...
There is an earth point for the coil packs under the inlet manifold on the gearbox end,
