Need some help with FORScan error codes.
Would like some help with the following DTC errors please.
Car is a 2008 Mondeo Titanium X 2.0 TDCI Saloon (140)
The errors come from FORScan v2.3.21 beta
Adapter is ELM327 v1.5 HS/MS switch
Quote
===RCM DTC B1126:11-8A===
Code: B1126 - Drivers Side-Side Airbag Deployment Control
Additional Fault Symptom:
 - Circuit Short To Ground
Status:
 - DTC Present at Time of Request
 - Malfunction Indicator Lamp is On for this DTC
Module: Restraint Control Module
===END RCM DTC B1126:11-8A===
Air bag warning light comes on and stays on (not flashing).
Seat hasn't been moved or got anything under it.
Car hasn't been in a crash.
I've disconnected the battery for an hour, unplugged/cleaned the yellow connector under the seat, unplugged/cleaned the two connectors on the module under the cup holder and checked the loom where I can get to it.
Any other suggestions as to what I should look at next or any tips on fixing this issue?
Quote
===PAM DTC B1B42:01-2F===
Code: B1B42 - Left Front Inner Sensor
 - General Electrical Failure
Status:
 - Malfunction Indicator Lamp is Off for this DTC
Module: Parking Aid Module
 Freeze Frame :
-GLOBTIM: 0 sec - Global real time
-TOTDIST: 0.0 km - Total Distance
-MAINECUV: 0.00 Volt - Main ECU voltage supply
-ESTSECRK: No  - Engine status - engine in crank
-ESTSERUN: Yes  - Engine status - engine running
-INCARTMP: -40 °C - In car temperature
===END PAM DTC B1B42:01-2F===
Can't turn parking assist on, in reverse gear or pressing dash button, just gives one long sound then nothing.
I swapped the front inner left and right sensors with each other and wiped the DTC's.
After the sensors are swapped the system still fails to activate but the SAME error comes back (I was expecting 'Left Front Inner Sensor' if it was a bad sensor).
I'm guessing this will be damage to the loom somewhere. Anyone suggest any common points the loom or connectors might fail?
Quote
===ACM DTC B1A03:13-2F===
Code: B1A03 - Speaker #3
 - Circuit Open
Status:
Module: Audio Control Module
===END ACM DTC B1A03:13-2F===
Quote
===ACM DTC B1A04:13-2F===
Code: B1A04 - Speaker #4
 - Circuit Open
Status:
===END ACM DTC B1A04:13-2F===
Sound comes from all the speakers so not sure what these errors are about (don't really care to much either).
Would be nice if someone could tell me which speaker is which though. #3 and #4 doesn't really help much.
Quote
===BCMii DTC B1108:77-6C===
Code: B1108 - Driver Door Central Locking Motor
 - Commanded Position Not Reachable
Status:
 - DTC Maturing - Intermittant at Time of Request
 - Tset not complete
Module: Body Control Module
===END BCMii DTC B1108:77-6C===
Door handle can sometimes need to be pulled twice to unlock the car (keyless entry) and has triggered the alarm once also.
Does anyone know if the keyless cars have the same central locking motor as the standard locking cars?
Thanks in advance to anyone who can give me some more information on these errors.
One other thing I just noticed, under VIN is says 'Testconfiguration' and not the cars actual VIN number.
I tired with the following:
  1. USB adapter, laptop and FORScan
  2. Bluetooth adapter, phone and three different apps
  3. Wired adapter, built in software.
They all say the same thing.
Anyone know what this is all about???
This sounds like your battery is not holding its charge properly. be worth checking on that as that is showing all the sign of it
I'll check the battery tomorrow and see what the voltages are showing. Do you know what battery should be fitted to the car? It's currently a Bosch S5 Battery (100) I fitted on 24/10/2017 has 74 amp hours and 750 cold cranking amps.
Geocacher - Just sent you a private message for some more details of the car.
  • 2 years later...
Hi, did you ever get to the bottom of the 'Testconfiguration' instead of the VIN number? Mine is doing the same and I think this is causing an issue with not being able to program some of the modules.
