DTC Code in Test F006_16
I recently purchased a 2018 Ford Focus SE and while learning some tricks to diagnostics, discovered I have a DTC Code of F006_16.  I called the dealership service department and they were clueless, telling me I needed to actually contact Ford.  Has anyone else seen this code or know which IDS code in converts too?
DTC codes that show via a dash menu mean nothing at all.
They usually refer to a module miscommunication and is often due to certain parts of the system being installed seperately on the line after the ECU goes live.
You can leave them be with absolutely no problems or use an OBD module to clear them off the system if they are bugging you.
Sent from my SM-G965F (S9+)
