Fuse Tap
I would like to clarify something. When using a fuse tap it looks like only one wire is there so what do you do for example if you wanted to wire LEDs that have two wires?
You need to provide a ground from elsewhere to whatever you are powering
Any body mounted metal screw or bolt will be sufficient.
Sent from my SM-G965F (S9+)
Ah thanks very much I was searching and couldn't find anything relevent now I get it 😁
