radio not turning on or off with ignition
hi i have a 2008 ford mondeo 1.8 tdci titanium
the sony dab radio radio doesnt turn on or off with the key.i have tried to remove the fuse and entered the code but still no luck.
also the dashboard isnt showing the radio channels it only shows 2 options settings and trip computer
the voice button on the stalk does nothin.
anyone any ideas.
ive scanned it wit fordsys i got 2 codes p006c which im not worried about but the other one i got was C28AA dont know what this one is.
https://1drv.ms/u/s!AqP_mdHb1GdQkxtecFsXE6VM7oiS
https://1drv.ms/u/s!AqP_mdHb1GdQkxrlL_56otszKPYb
any help would be great thanks
C28AA isn't a DTC
ok thanks
The problem is the stereo is no longer talking to the car so the dashboard won't display any radio info because it doesn't know the radio is there.
As for why that's happened I don't know, I see you've tried pulling the radio fuse but have you tried disconnecting the battery itself for a few minutes?
only got the car today.i disconnected the positive cable only ill completely disconnect it 2morrow cheers
disconnected both terminals on the battery no luck tho.
maybe im doing it wrong do i need to leave positive terminal on and disconnect the negative
the trip meter hasnt reset tho but clock did
also when i entered my radio code the channels where all still stored?
any more ideas guys thanks
Edited by voodooirl
might be worth you looking into a program called Forscan.  It might give you some error codes so you can look up what the problem.  www.forscan.org
It's generally best practice to remove the negative terminal.
Yes this all happened on my Focus when I changed the battery. I was quite surprised the radio held its channels tbh.
Although both methods will achieve the same thing.
  • 8 months later...
I have this same problem....anybody solve it yet?
  • 4 months later...
Also same problem..
  • 4 months later...
Hi. Has this radio issue been resolved yet?
I have the same problem.
  • 3 weeks later...
Any one sort out this issue??? I have this problem to! FORD MONDEO MK4! First time I had problems with wipers...doesn't stop from controller .... and now with the radio... is a electric problem but I don't know where.
  • 1 month later...
Same issue anyone got a fix.
  • 4 months later...
I have the same problem . Tried out ion test light to all wires on the back of the radio and seams like no power.
any one know which the power lead (colour wire) it should be going to the back
2009 titanium x, Sony cd
Brown/red. Should supply power via fuse f6 in footwell fusebox.
Did any one get this issue fixed got same problem. Read on Google about pulling fuse f6 then refit.didnt work.
  • 4 months later...
Take the front of radio heat up with heat gun 30 secs put back on sorted mine
  • 5 months later...
h
Had the same problem. Changed ignition switch (£22) working great now. Quite a simple job too.
  • 1 year later...
I have a very sticky on / off switch on the radio… possibly something to do with that.
I manually have to pull it out, to get it to work again. Occasionally forget and find the radio keeps turning itself (& digital systems in the car) back on.
Car is 2017 smax vignale - Sony radio.
  • 4 months later...
I've just had the same problem. EASY FIX HOLD THE OFF/ON BUTTON FOR 20 SECONDS. THE RADIO RESETS.
