Installing reversing camera
Whats the best way? Find a cheap crappy one from online or just take it to fords and let them do it. Fords camera alone is £171, not to sure on the fitting.
Last time I asked Ford dealer said 3 hrs at 100/hr
Took me about 3hrs to do mine, camera + harness = £30
holy *****.
does it work exactly how you want it to? As soon as you put it in reverse your camera pops up? I have a 2012 titanium focus. Don't know what im doing haha
9 hours ago, Jamey0512 said:
holy *****.
Yeah, it works perfectly. The only thing it doesn't have is the dynamic steering lines, it has the red\yellow\green lines.
My car has Sync3 though, I know it will also work on Sync2 but anything less than that and I'm not sure. You also need to activate the camera service via forscan.
I went the Double DIN aftermarket head unit route. The HU came with a camera, but it was a daft looking thing, like a wee cube with an LED in each corner. Found a better one that replaces one of the original number plate lights. It has a trigger from the reversing lamp circuit, and the rear view pops up on the head unit straight away: it doesn't have to wait for Android to boot. The camera is "hard wired" for want of a better phrase, and as such is operating-system independent.
HU, reversing cam, forward facing cam and fascia adapter cost me less than £200. 3 hour job, including making up the wiring loom. The head unit loom comes with a connector on only one end, so I bought a Ford Quadlock to Pioneer harness adapter, chopped off the Pioneer end and soldered, heat-shrunk and taped the lot. Tedious, but does a good job.
