High Level Brake Light Focus Hatchback
My focus just failed the MOT on the centre brake light not working.
I have discovered that there are several bulbs in there.
My question is how do i remove the light cover so far i have unscrewed the cover and i can pull it away slightly
as i was doing this i noticed the light come on so its not a bulb problem.
the bulb holder just seems to be sitting in there loose
any ideas how i can fix this problem
thanks
It most likely is a bulb with a loose filerment and when you moved the lens it touched together again but the bulb will need replacing.
I beleave that if you open the boot there should be two rubber gromets on the inside near where the lens is sitting, remove them and and gentle lever with a flat bladed screwdriver.
