Upgrade GPS map from F5 to F8
Hello forum
I have an Ford C max model 2015 installed with Sync 2 and the F5 map on a sd card.
I ordered an upgrade map from my Ford dealer and last week I received F8 map on so card. I have installed the new sd card - in the beginning the system did not work proper. The pop up with “Calculating route” did not disappear- and the route was not calculated correctly. I switch to the old card and after a few tests it work ok. I changed to the new card and again after a few tests it seems to work ok.
My question is - is F8 card compatible with Sync 2 ? I think I read somewhere that it require sync version 3.2
Screen dump from system information
https://photos.app.goo.gl/2jASegJbGW4vP7fU6
Regards
Jens Krogsgaard, Copenhagen Denmark
Surely it must be compatible as it's on a card? Sync 3 doesn't use SD cards. Mind you, it is Ford Technology so I may be making a huge assumption!
Just put it back in and leave it, it will work fine.
