Dash Cams
Hi I wish to fit a dash cam to 2007 cmax,how do I remove trim panel roof to dash near side any help would be appreciated.
Regards Tony
On my 2018 there wa no need to remove the trim you can get enough movement to tuck the wires in,
Hi I wish to fit a dash cam to 2007 cmax,how do I remove trim panel roof to dash near side any help would be appreciated. Regards Tony
That's the A pillar trim.No need to remove it, just pull the rubber trim away from around the area by the front side of the door and tuck the cables in behind.
When you get to the transition point between the trim and headliner just tuck the cable in and you'll find it straightforward to hook the cable under the corner of the headliner and then between the roof and headliner along the top of the windscreen.
If it's like on my previous mk2 Focus you'll find there's a slight lip on the edge of the roof panel that helps to hold the cables in place.
Just tried to upload a video, but iphone videos dont load so heres a pic, hope it helps.
