SportKa Brake Issues
I have a 55 reg SportKa and have some brake issues. Was driving along and broke hard and now the brakes are not as good as they were. The pedal goes to the floor before you get any braking action but recovers after a few pumps. The brake pedal then goes to the floor again as if no pressure is in the system. Had the system bled and fluid changed but it has not improved. I have also changed the servo as I had access to a cheap one - all that has done is removed the hissing sound when applying the pedal.
Is this likely to be a master cylinder fault?
Thank you!
