Engine Fan Stays On After Switch Off
Hello i had an accident with my ford c max II (2011). The front of the car was destroyed, including the fans. I repaired the car, inserted new fans. However, when I turn off the car, the fan still runs until the battery runs out.
Do you have any idea what needs to be done to solve this problem?
Check all the wiring is the best I can come up,with.
Is it possible that main procesor/computer is corupt?
Might be but I would check the basics first, wiring does vary between model years 1 pin out would do it. The wiring could be damaged and you have a short,.
Check the Rad thermostat .
