Problem with Fuel pump
Hi..my name is Fahmi..i'm from Malaysia...own a Mondeo 2.0 Ecoboost (Titanium Spec) year 2012.. Recently error code showing up (fuel pressure too low)..is it because of the fuel pump?
Replace the fuel filter first.
Hasn't got a conventional fuel filter . Only filter is part of the in tank pump.
Fuel pressure sensor would be my first check, poor connections
[emoji20]
If fuel pressure sensor CONNECTIONS are bad, the ecu will record a different ERROR plus eml light would be flashing.
Could still be worth checking the filter on the pump... after all the car's 7 years old now.
  • 2 years later...
I have recently purchased a 2012 FORD MONDEO ZETEC Hatch MC 2.0L PETROL turbo ECO BOOTS which has the Engine light on and doesn’t Idle and take off smoothly from a standing start. Once I take off and up to the speed required it runs fine.
I took it to a mechanic and he plug in his device and diagnosed that the HIGH-PRESSURE FUEL PUMP showing
No photo description available.
, has anyone experienced this issue and what can I do to fix it?
Note replacing HIGH-PRESSURE FUEL PUMP on this model is over $500 plus labour, I want to be a 100% sure that this will fix this problem as my mechanic said "it may also be a clogged fuel injector etc" This will be an additional cost which I would like to avoid if possible.
Your feed back would be greatly appreciated😏😏😞
