Intercooler/Turbo pipe corrosion
I bought a Mondeo Estate 2011 about 2 weeks ago in Germany where I'm stationed and during an inspection/service a pipe was discovered with corrosion and being held together with old fashioned duct tape. I think it connects the intercooler to the turbo but I'm not 100% on what direction the air flow goes. For the life of me I can't find the part online (I'm not a mechanic). I've attached a pic for reference.
Assuming someone can ID the part, since its a LHD model, does it matter if i order it in the UK or does it need to come from a German supplier. The timing belt is on the right (passenger) side of the vehicle and this pipe is on the left (drivers) side.
I'm also missing the under engine plastic shield, anyone know a part number for this?
Link to the images
https://imgur.com/a/NvZotqK
Thanks in advance
GW
Send me your vin number via PM and I will try to help you.
GW
Take a look at the pic that i added, is that it?, if not, remove the upper cover and then point the tube. a5b1c2e57d73d8dd5c37d47283201f7f.jpg
1 hour ago, rbitton782 said:
GW
I don't think thats the part mate...
I'm starting to narrow it down a little but still no part number
Someone here is speaking about the rubber tubing blowing up stream of the pipe that I'm talking about. The metal pipe below it (the one thats causing me the issue) either comes as 1 part, 2 parts or 3 parts.... depending on the schematic i look at. I'm pointing at it in the THIRD picture.
Schematic options...?
I noticed when researching that the part was noted as a 6c646 pipe. However when i Google it specifically i find that its either for the wrong side of the intercooler or its for the upper or lower on the correct side. Nothing comes up for the middle pipe(s)...
GW
Find it!
After taking a closer look at the pic that you added, you can see narrow pipe(belongs to the cooling system) that chafing the intercooler pipe, may be you have tiny hole that caused water dripping which you see rust.
Take a second look before order a new intercooler pipe. af6d2bfec6254da15ddac44d75ca30be.jpg121fcd819db08f0495abf7a52499874a.jpg
10 hours ago, rbitton782 said:
GW
Find it!
Thanks for the help. That CatCar image is difficult to make out. Can you find the part(s) i need on autodoc and link them please?
GW
Your part number is 1707514, this pipe is one part, it's divided to sections.
