Won’t start
Ford c max 2013 keyless tried starting it 4 hrs ago & says Engine Start Pending. Any advice..
You get that when it's cold it should start if you keep the clutch depressed
Presumably it's a diesel? As Pete says there'll be a delay for the glow plugs to heat up in cold weather.
It's quite noticeable that on the ecoboost I have now it fires up the instant you hit the button, but on my Focus tdci (and a Land Rover I had with a similar system) there could be a lengthy pause in cold weather after you'd pressed the button and taken your hand away.
