Glass Door Trim Removal
Hi All
Does anyone have any idea how to remove these panels (pic attached)? They may be plastic but look like glass.
I need to strip my original door as I have a replacement but its bare, so need to move everything over.
Thought about pulling them to see if they just pop off but it'll be an expensive mistake if it doesn't work.
Cheers
Martin
They're plastic.  They clip on using 3 plastic clips and 'hook' around one edge.  I think you just need to pull them but would double check there aren't other fixings first.
As above but its best done when warm it may save the clips, you can use a hairdryer to get a bit of warmth into them as the door is loose a warm place in the house for a few hours will help. There is double sided tape too.
