o/s rear knocking noise
Under heavy braking I am getting a knocking noise from the rear off-side wheel.Have just had all new discs and pads.Any ideas ?
Open the boot and push up and down on the rear boot lip. Does the knocking occur with the suspension bouncing up and down?
Check the wheel is on the hub correctly. If you get hold of the tyre and rock it by pulling and pushing it, does it still knock?
Check the bolts are tight on the back of the caliper. You would hope a mechanic would have checked this though.
