mondeo MK4 master Cylinder
Looking at Changing my Clutch Master Cylinder.
is there  guide/Video anywhere ?
does the Steering Column have to come out ?
Thanks in Advance
Tony
In brief, according to the Haynes manual you need to remove the steering column and then clutch pedal with master cylinder attached, then rotate the master cylinder off the pedal.
Yes the steering column does have to come out , very important that you don't move it from its position, not the easiest job I did on a mondeo but the Haynes manual is for once a decent guide.
