SATNAV fault
My Kuga 2016 TIT X as a faulty SATNAV
When the ignition is on it does not pick up any satellites, but when I turn the ignition off it shows 8 satellites!
Help as I have no idea what is causing this.
Any advice would be great
Regards Dave
I have found that it is my dash cam that is stopping the GPS signal, when I disconnect the dash cam power feed the satellites come on line.
so I either need to screen the gps aerial or move the dash cam to a different position.
I had that with a cheap dashcam, got a decent one and no issue since then.
It doesn't tend to be the camera itself.
More commonly it's the power cables that cause the problems due to RF interference and mostly from the plug that goes into the car's 12v socket.
On a previous car I found I had problems with the central locking not responding.
Once I fitted a hardwired power supply (which was properly shielded) the problem stopped.
If you really prefer a plug-in supply try adding some clip-on ferrite cores to reduce the RF.
Sent from my SM-G965F
