Mondeo mk5 total lockout
HELP my mk5 vignaile has locked me out both key fobs won't work tried blade key for manual operation but this failed to open it all garage are closed due to Corona so potentially it could sit there for months 😥
If anyone has info or a hack 🤗 cheers chris
HELP my mk5 vignaile has locked me out both key fobs won't work tried blade key for manual operation but this failed to open it all garage are closed due to Corona so potentially it could sit there for months [emoji26]
If anyone has info or a hack [emoji847] cheers chris
Join this group on Facebook, someone will be able to help you
https://www.facebook.com/groups/693277794183606/
Have you tried both blades? There should be no problem opening the door manually with the blade. Once you remove the cover off the door handle you should be able to turn the blade, it can be a bit stiff so you may need to hold the blade with a pair of pliers for leverage
Many thanks jonro I'll try that but will it start if not detecting key as it's keyless start
There is a place to put the key in the central armrest at the front, you drop the fob into it and it 'should' respond.
Yes I'm in used pliers to turn lock thanks again jonro but no start 😥
You will probably need to charge the car battery
You were spot on flat battery got AA I must have left something on when cleaning 🙄 thanks very much for your help 🤗
No problem, glad to have helped a little.
You should join our group, it really I as a huge pool of knowledge and a friendly place to be, Just what we need at times like this. I can hand on heart say we have no trolls in the group and we all help each other
