DRL'S
Hi,have a 17 edge sport and the drivers side drl isn't working, does anyone know what bulb it is please, thanks
This topic talks about replacing them all with LEDs so not exactly a replacement for a standard halogen but might help with location/type maybe...
You need a H15 (715) bulb.
Hi, is the drl same bulb ie dipped bulb thanks
Ok thanks
Ok, so I replaced the H15 drl high beam bulb and the drl part of the bulb still not working on the drivers side but high beam does work, so I then took bulb from passenger side and put on drivers side still not working only high beam so it's not the bulb, anyone had this problem thanks
Have you checked the connections? Probably best to remove bulb and connector and test it.
