Dash Lights and rear lights not working
sorry if this topic has been discussed but i did not find anything in the 80 pages i gave up at page 30. i got the 1300 fuel injection ford ka 2008 model. the one with the color coded bumpers. my speedometer cluster lights does not work the park lights front and rear does not work and the unit where you switch the aircon, fog lights, and rear window demister does not work either. Our local for dealer wants me to replace but i feel it is too expensive and there could be a simple solutions rater. I did check all the fuses. not just checked it megged the out with a tester making sure there is continuity on them. there is no other fuses or relays in the car except the fuse box. and only two relays in the engine compartment. What else am i missing. need a fix fast as i bought the car on friday and need to send it to roadworthy test center in order to register it on my name but it will not be able to go till i find the issue
Faulty switch?  Get to the plug on the switch. Find out which pin is power to switch and which pin is power out to sidelights and bridge them to see if works, and if so it would seem it is switch.
