Error codes help
Ford focus 1.6 tdci mk2 (2006)
Can anyone help me with these error codes please.
I was having a underboost issue, driving was very flat.
took egr out to check, on refitting i noticed it wasn't seated in the cooler as the mouth was bent. fixed that and popped in a new map sensor.
Boosts now although the car doesnt take off until 2.5 / 3k revs
Now this error has popped up?
Have you tried clearing all the DTC’s and doing a reset? That may help :) I had to do that when I had a bad o2 sensor.. even with the new one in place it still ran like a bag of spanner’s until I cleared all the codes and did a reset. I pulled the battery for that then reconnected!
Sent from my iPhone using Tapatalk Pro
I've cleared the codes although on doing another scan it say they are now pending...
But cleared again just for hood measure and now disconnected the battery while I'm at work... fingers crossed.
Are there any fuses or relays I could check in case I've shorted something?
Failing that... is there any software knocking around to do a dpf / egr delete?
