Washers
Front and rear washers not working. Pump has been replaced and pipes cleaned but still hasn’t corrected it.  After pump was replaced water was coming out the rear only but has now stopped altogether. Help
Does the pump squirt water out if the pipes aren’t connected ?
If not, is there voltage at the connectors.
Is this a new Focus? I've had issues where the pin grips were poor on the connector for the washer pump causing this fault.
