Possible fueling issue
Good evening,
I have an issue with my 1.8tdci and was wondering if anyone has had the same issue.
When driving at motorway speeds in 5th gear, if I roll off the throttle taking the engine from load to breaking and roll back on the throttle I get a cloud of white smoke and a back fire, but only above 2000rpm. If I dip the clutch, let the revs drop and  then match the revs to re engage the issue doesn't occur. It appears that it happens when going from load to no load then back on load,  The car drives fine at all other times, it doesn't burn any oil and fuel economy is normal, there are no fault codes displayed at any time.
Sounds like an overfuelling injector..... the white smoke is caused by unburnt fuel. You need to have them tested and I don't mean just a leak-off test.
