One horn two horns where are the
2017 titanium UK
Horn for this car was pretty crap. Asked the dealer to check if one horn was not working.
They said only one horn fitted.
Now it wont work fuse and relay ok and power when you hit the horn button. Can anybody tell me where the blasted horn is?
Seen the 2019 video fitting two horns however mine is not in that position under the nearside headlamp. Help locating it would be a great help
Gordon
According to the info I have it's under the front slam panel. You should see the fixing bolt head on the top of slam panel to the right .
But unfortunately the front bumper and active grille shutters assy needs to be removed so you can access the horn assy . Labour time at a garage is 1.6 hours. Good luck
Hi All
Was not aware that they made an Edge with just one horn (though I could be wrong). My 2016 Edge has twin horns, one of which packed up and replaced under warranty couple of three years or so ago, and recently been going between one and two tones. Must admit sounds pretty feeble like a castrated duck when only one tone working.
Stay safe
Happy motoring
Dave
Sent from my SM-J600FN using Tapatalk
