Rear subframe bolt Torque Values
Does anybody know the exact torque values for for the 2009 focus. It's the 6 bolts that hold the rear subframe to the car?
I have scanned Haynes manual but can't find them. They have the trailing arm bush bolts and the others but don't see the values for those  main 6 bolts.
Cheers
Cheers
Maybe it's under crossmember mounting bolts.My MK1 is 115 Nm if that helps👍
Rechecked no, still don't see it. Will have a Google and check
Pm me your reg, I’ll check for you.
Thanks, will pm it now.
125nm
Just now, iantt said:
125nm
For the whole 6 of them?
Yep
I'm assuming it's hatchback and not estate?
Edit, estate the same anyway
Yes the MK2.5 hatchback
I’ve got 115Nm here but close enough lol
So what shall it be 115 or 125NM? Or  I hit it at 120NM that should so it.
Stef would say 3 dugga duggas
Took the words right out of my mouth Ian :lol:
Gotta be careful with the dugga  duggas on these Milwaukee 3/4” guns
Thanks fellas , helped me out s lot this evening, appreciate it. 👍👍
Just when we're here, I have new control arms installed . I will have to get the car realignment done but is there any neutral way to adjust these bolts untill then or does it not matter which which they go?
At the moment I have them both facing the same way on both sides.
