Can someone read these codes and decipher them for me...
I have an ABS, Traction Control warning The FORSCAN text file -
===PCM DTC P0670:00-6C===
Code: P0670 - Glow Plug Control Module 1 Control Circuit / Open
Status:
 - DTC Maturing - Intermittent at Time of Request
 - Malfunction Indicator Lamp is Off for this DTC
 - Test not complete
Module: Powertrain Control Module
===END PCM DTC P0670:00-6C===
===PCM DTC P037D:00-2C===
Code: P037D - Glow Plug Sense Circuit
Status:
===END PCM DTC P037D:00-2C===
===OBDII DTC None===
Successful DTC reading, no error codes found
Module: On Board Diagnostic II
===END OBDII DTC None===
===SASM DTC None===
Module: Steering Angle Sensor Module
===END SASM DTC None===
===ABS DTC C0034:15-20===
Code: C0034 - Right Front Wheel Speed Sensor
Additional Fault Symptom:
 - Circuit Short To Battery Or Open
Status:
Module: Antilock braking system
 Freeze Frame :
-GLOBTIM: 237703643 s - Global real time
-TOTDIST: 0.0 km - Total Distance
-MAINECUV: 11.75 V - Main ECU voltage supply
-OUTTMP: -40 °C - External Temperature From Sensor
===END ABS DTC C0034:15-20===
===ABS DTC U0100:00-68===
Code: U0100 - Lost Communication With ECM/PCM A
Status:
 - Previously Set DTC - Not Present at Time of Request
 - Test not complete
 Freeze Frame :
-GLOBTIM: 189983599 s - Global real time
-TOTDIST: 119300.0 km - Total Distance
-MAINECUV: 14.25 V - Main ECU voltage supply
-OUTTMP: 23 °C - External Temperature From Sensor
===END ABS DTC U0100:00-68===
===ABS DTC C0037:4A-68===
Code: C0037 - Left Rear Wheel Speed Sensor
 - Incorrect Component Installed
Status:
 - Test not complete
 Freeze Frame :
-GLOBTIM: 252594470 s - Global real time
-MAINECUV: 12.25 V - Main ECU voltage supply
===END ABS DTC C0037:4A-68===
===ABS DTC C0037:07-68===
 - Mechanical Failures
Status:
 - Test not complete
 Freeze Frame :
-GLOBTIM: 252518400 s - Global real time
-TOTDIST: 178639.0 km - Total Distance
===END ABS DTC C0037:07-68===
===ABS DTC C0037:11-68===
 - Circuit Short To Ground
Status:
 - Test not complete
 Freeze Frame :
-GLOBTIM: 252515399 s - Global real time
-TOTDIST: 178541.0 km - Total Distance
-MAINECUV: 14.00 V - Main ECU voltage supply
===END ABS DTC C0037:11-68===
===RCM DTC None===
Module: Restraint Control Module
===END RCM DTC None===
===PAM DTC U0415:86-28===
Code: U0415 - Invalid Data Received from Anti-Lock Brake System (ABS) Control Module A
 - Signal Invalid
Status:
Module: Parking Aid Module
 Freeze Frame :
-GLOBTIM: 215324017 s - Global real time
-TOTDIST: 144077.0 km - Total Distance
-INCARTMP: 23 °C - In car temperature
===END PAM DTC U0415:86-28===
===PAM DTC U100B:00-28===
Code: U100B - Semi-Automatic Parallel Parking System
Status:
 Freeze Frame :
===END PAM DTC U100B:00-28===
===HCM DTC B1C99:13-64===
Code: B1C99 - Right Corner Lamp Circuit
 - Circuit Open
Status:
 - Test not complete
Module: Headlamp Control Module
===END HCM DTC B1C99:13-64===
===PSCM DTC U0415:00-08===
Status:
Module: Power Steering Control Module
 Freeze Frame :
-GLOBTIM: 252917127 s - Global real time
-TOTDIST: 178993.0 km - Total Distance
-PWR_MODE_KEY: Running  - Power Mode Key State
-PWR_MODE_QF: Power Mode OK  - Power Mode Quality Factor
-SSHFT_TQ_S2: -1.9 Nm - Steering Shaft Torque Sensor #2
-MOD_SUP_V: 14.30 V - Module Supply Voltage
-PSCM_INT_TEMP: 19 °C - PSCM Internal Temperature
-VSS: 16.0 km/h - Vehicle Speed
-DLA_SED_FD0B_PID: 204   - DL_SED_FD0B_PID
-DLA_NUM_FD0C_PID: 0.00 A - DL_NUM_FD0C_PID
-DLA_NUM_FD0D_PID: 0.00 A - DL_NUM_FD0D_PID
-DLA_NUM_FD0F_PID_1: 0 1/min - DL_NUM_FD0F_PID_1
===END PSCM DTC U0415:00-08===
===BCMii DTC B1D01:15-68===
Code: B1D01 - Right Low Beam
Status:
 - Test not complete
Module: Body Control Module
 Freeze Frame :
-GLOBTIM: 231738939 s - Global real time
-TOTDIST: 160121.0 km - Total Distance
-MAINECUV: 14.75 V - Main ECU voltage supply
-INCARTMP: 80 °C - In car temperature
===END BCMii DTC B1D01:15-68===
Ive taken out the Front Right (Drivers) sensor, cleaned it and the area around it and the hole it drops into.
Had the rear left (passengers) sensor, cleaned it etc..
I also took off the under panelling and checked the lengths of wiring exposed front and rear, no obvious breaks or kinks.
I drove the car, the faults cleared themselves.... after about 15 minutes, the lights came back on.
Any reason why the FRONT RIGHT and REAR LEFT would BOTH be showing faults???
Front right and rear left are on one brake circuit, and front left and rear right are on the other brake circuit. So if a hydraulic pipe fractures you've still got some braking.power.
That makes sense, I guess.
i swapped the front sensors left/right and cleared the codes. Now only rear left is showing a fault code. I’m wondering if I messed up and didn’t clear old codes, so they might have been historic.
