Water ingress
Ford C Max 2019. Just checking all ok under bonnet and noticed leaves where the bonnet hinges recess into the bodywork.
removed leaves both sides to find the recesses were both full of water.
any advice please. Anyone else come across this . Thank you .
I have a Ford C Max 2016 and also have the same problem but only on the drivers side. I push a dry cloth in to the recess to soak up the water.
Not sure if there is a drain hole which gets blocked up with leaves and gunge.
