MkII wishbone / ballpoint query (quick question)
I'm the position where I'm going to replace the wishbones (ball joints need changing but thought it'd be less painful to replace wishbones altogether).
I don't have a ball joint seperater and am wondering if I'd need one if replacing the wishbones (I assume I'd just be able to dislodge the ball joints with a hammer blow if required)?
Any quick replies are most welcome.
Thanks.
You shouldn't need a Ball Joint Separator for these cars. The last time I did one I was surprised how easy it came apart with just a hefty Tyre Lever. Failing that then a few blows with a hammer should work ok.
Yep as above and its upto yourself here is a simplified video it's very easy to do.
Wow. . Thanks to you both for a helpful and super quick reply!
