Clutch Pedal Replacement
Has anyone had any experience of replacing clutch pedal??
Car going in next week to replace but garage said its an all day job. Previously they said it would take couple of hours but after working on it it for an hour last week they apparently realised it was a bigger job than they anticipated.
If you know what your doing it takes just under 90 mins to remove and refit clutch pedal . Fiddly bit is getting the clutch master cyl off pedal if you don't have the special tool to remove it.
It's just a case of uncoupling the clutch master pipes off ( under bonnet)  a few interior trim bits moving the steering column shaft to one side then undo 4 nuts . Off it comes .
At first they said it would take a couple of hours but now they are saying its an all day job which is gonna cost me more. I don't have a clue. I understand the basics and principles of how cars work, just got a little feeling that they might be taking me for a ride
Why are you needing the clutch pedal replacing?
its sticking, once pedal has engaged its only coming half way up
