Scuff Plates front, with illuminated Focus logo
Hi
I have just got myself the Scuff Plates front, with illuminated Focus logo for my 2015 focus titanium x with the correct ford wire assy but when i plug these in the light stays on all the time is this correct  thank you
Would expect them to turn off when door is closed just like the interior light.
11 hours ago, John906 said:
... when i plug these in the light stays on all the time is this correct  thank you
When you say 'all the time', does this mean even when the car is switched off with the ignition key removed?
Where did you plug them in?
Hi
I plug them in the foot well lights is this correct i have attached photo of the ford wiring for it
Hi i plug them in to make sure they work so before i fit them in place i put them in the foot well to see that they go off but when you close the door and lock the car they still stay on
This is probably a stupid question, but have you waited a couple of minutes just to make sure they don't go off? The footwell lights have a built in delay, they don't go off the instant the door is shut...
Yes i did i waited 5 minutes and they was still on
If you connected to the footwell lights, and they turned themselves off after delay, and your sill plate stayed on, well it is not getting it's power supply from your footwell lights, it is getting fed from a permanent 12v supply...
