Headlight dipped beam failure
Hi
I posted the below query on the Ford Edge FB page last night, but just wondered if anyone on the forum here may be able to help or advise.
Many thanks
Headlight failure. I have a 2018 sport that originally had candles. 18 months ago I upgraded all the front lights to LED’s using the recommended ones from other people on here
Have had no problems at all in 18 months until tonight
Went out and while driving thought blimey my lights are dim
Pulled over and checked and both front headlights were not working
Sidelights were on and full beam works in auto beam mode and manual and front fogs work but no dipped beam
Got my son to turn the dial from sidelight to dipped beam and when you turn to dipped beam there is the slightest glimmer in both bulbs for a second but then no other light
If one bulb had gone fine but both bulbs?
Fuse problem or any other suggestions??
One of the bulbs is shorting and this may switch both off to protect the circuit. Both dipped beams are switched on by  the body control module. No fuses as such. It's a bit like your house trip switches , when a device shorts it trips to protect .
Iantt
Thanks for your comments
I have swopped the LED's out for the original Halogen H7's (candles) and both of those work fine..??
Therefore would you say both LED's have failed, or, it could be a short on one of the bulbs?
Just confused why the original Halogens work but the LED's dont
Many thanks
One of the LEDs has failed. It shuts the circuit down. Put the halogens back in and bcm detects bulbs ok and powers the circuit up again.
Iantt
Cheers mate
It might be the Body Control Module has locked up. After the original bulbs were refitted and they worked, try refitting the LED's.
H
