Master clutch cylinder
Hi all
Notice the floor was wet , looked up to find the master clutch cylinder leaking
Is it a hard job to do ?
i've done one on same era fiesta (2004) which i think is much the same but not 100% certain. the cylinder was pretty cheap (mine was plastic). It was not a technically hard job to do but you need to be a bit of a contortionist to get up under the dash to remove the bolts holding the cylinder on.   I've seen it said many times they are really hard to bleed but I have not had that problem.
Thanks for your input mate
Been looking and it doesn't look to hard ( I've done worst jobs )
I'm going to do it next weekend , and will report back
Thanks again mate
